Body Cap Lens 9mm Bilder ( offen )
dinus
Beitrag von dinus » Samstag 2. Juli 2016, 22:11
Hallo Zusammen,
gerne würde ich mit Euch Bilder mit dem Fisheye 9 mm Body Cap von Olympus gemacht wurden austauschen.
Natürlich ist das Teil nicht ein hochwertiges Objektiv, aber als Einstieg in diese Perspektive sicher ein Blick wert.
Hier meine Ersten Bilder, einige davon mit Hugin entzerrt.
Wer hat noch Bilder zum zeigen?
Folgendes habe ich noch zum Fokus Schalter gefunden.
1) Barrier Closed
Obviously the lens cap is fully closed when the lever is slided to the lens barrier option, and you do want to protect the glasses (yes, REAL optical elements in the body cap lens) when you are not using it.
2) Infinity Focus
Use this for subjects that are very, very far away, eg buildings, ocean, sky, mountains, etc.
3) Deep Focus
When shooting subjects from half a meter (0.5 meter) and further from the camera, slide the focusing lever to the Deep Focus option. This will be the most used option, so when shooting I will usually set the focusing lever to this position by default. Even when you are shooting far away subjects (to infinity) using this option, the subjects at great distance may still appear in focus and sharp.
4) Close Up Shooting
This is the tricky part, and you do need to pay closer attention when shooting subjects closer than half a meter. The closest focusing distance is 0.2m. If you do set the lens focusing lever to 0.2m, you must make sure that the subject is really at that distance. Although fixed at F8 allowing for wider depth of field to cover some focusing inaccuracy, I still find tendency of having out of focus images if I was not paying close enough attention. How do you focus on subjects not exactly at 0.2m? Between 0.2m to 0.5 meter you do need to manually slide the lever from the position of Deep Focus to Close Up Shooting.
Gruss Dinus
Bilder
TZ31 & GX8
Matthes72
Re: Body Cap Lens 9mm Bilder ( offen )
Beitrag von Matthes72 » Samstag 2. Juli 2016, 23:43
Kann man das bitte in die richtige Rubrik verschieben ?
bis bald,
Matthias
dietger
Beitrag von dietger » Samstag 2. Juli 2016, 23:54
Weiß nicht ob ich diese Bilder hier im Forum schon mal
gezeigt habe, passen aber jedenfalls in diesen Thread ;)
Dietger
P1010072 by Dietger Arnst, auf Flickr
P1090439 1 by Dietger Arnst, auf Flickr
P1070489_SW by Dietger Arnst, auf Flickr
Beitrag von Horka » Sonntag 3. Juli 2016, 09:33
Hier gibt es irgendwo einen Thread, in dem einiges zu dem interessanten Objektiv gesagt wurde. Auch zur Unendlich-Einstellung (auf Deutsch).
Retina1
Beitrag von Retina1 » Sonntag 3. Juli 2016, 11:18
der leider in Verruf geratene Bahnhofsvorplatz in Köln
Gruß Klaus
dietger
Beitrag von dietger » Sonntag 3. Juli 2016, 12:30
Die Wuppertaler Schwebebahn
P1060987 by Dietger Arnst, auf Flickr
P1060973 by Dietger Arnst, auf Flickr
Retina1
Beitrag von Retina1 » Sonntag 3. Juli 2016, 12:50
Beim ersten Schwebebahnfoto passt es hervorragend.
Hier mein Dom nochmal in DXO bearbeitet
Gruß Klaus
Christoph O.
Beitrag von Christoph O. » Sonntag 3. Juli 2016, 14:11
Sehr interessante Optik!
Da wird jeder Platz und jede Straße zur Halfpipe! ;)
Christoph
Beitrag von mopswerk » Sonntag 3. Juli 2016, 14:58
Das Teil kann auch Infrarot ohne Hotspot:
Für Gelegenheitsschüsse brauchbar, und man kann sogar das Teil hochrüsten, um 58mm Filter dranschrauben zu können ( http://helge-suess.com/hardware/filterh ... cl-9mm-fe/" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false; ).
Das Teil ist aber eher nur eine Gaglinse, für kleines Geld bekommt man zB ja auch schon das Samyang 7,5, das nicht so derbe in den Ecken verschwimmt.
dinus
Beitrag von dinus » Sonntag 3. Juli 2016, 21:23
tolle Bilder, habe heute auch noch eines gemacht.
Leider habe ich den Thread auch mit unterschiedlichen Suchbegriffen nicht gefunden. Hier aber die Erklärungen in Deutsch.
1) Abdeckung geschlossen.
Zum Schutz der Gläser (Ja es hat wirklich richtige optische Element in dem Gehäusedeckel ) wenn der Gehäusedeckel nicht genutzt wird.
2) Unendlich Fokus
Dies ist nur für Objekte welche wirklich sehr weit weg sind also Gebäude, Meer, Himmel, Berge, usw.
3) Tiefer Fokus (Punkt)
Wenn das Objekt einen halben Meter (0.5 meter) und weiter von der Kamera weg ist. Dies sollte die meist gebrauchte Position sein. Auch wenn das Objekt weiter weg ist bis hin zu unendlich kann diese Einstellung genutzt werden. Die Objekte mit grösserer Distanz werden noch scharf abgebildet.
4) Nahbereich (0.2m)
Dies ist der schwierige Teil, wenn das Objekt näher als 0.5 Meter ist, wird diese Einstellung genutzt. Die Nahgrenze ist 0.2m. Wenn Sie 0.2m eingestellt haben müssen Sie sicherstellen dass das Objekt wirklich diesen Abstand hat.
Da die Optik auf F8 fixiert ist ermöglicht sie eine relativ grosse Tiefeinschärfe. Trotzdem wird ab und zu ein unscharfes Bild entstehen, wenn Sie nicht genug darauf achten.
Doch wie wird auf Objekte fokussiert welche zwischen 0.2m und 0.5m Abstand haben? In diesem Fall müssen Sie eine Position von Regler zwischen 0.2m und 0.5m (Punkt) einstellen.
Bilder
TZ31 & GX8
dietger
Beitrag von dietger » Sonntag 3. Juli 2016, 22:21
....und zwar gleich 5 Stück.
Dietger
blueriver
Beitrag von blueriver » Montag 4. Juli 2016, 19:00
Auch im Makrobereich kann diese Linse ganz neue Perspektiven eröffnen:
Nur verkleinert und leicht geschärft.
Ein Ausschnitt zeigt, dass die Qualität garnicht mal so übel ist:
Konrad.
Weiß das gemeine Volk
Daß es Krieg gibt.«
Bert Brecht
Rolleum
Beitrag von Rolleum » Dienstag 5. Juli 2016, 02:10
Sag mal einer, das wäre keine Profi-Linse. Okay, Blende 8 ist nicht so der Brüller, aber die Fotos sind echt toll ! Kompliment an alle , die diese schönen Fotos hier reingestellt haben. Für den Kurs von knapp 90€ wirklich interessant.
dietger
Beitrag von dietger » Dienstag 5. Juli 2016, 10:55
Die Hattinger Altstadt mit dem BodyCap.
Dietger
P1030854_SW by Dietger Arnst, auf Flickr
P1030839_SW by Dietger Arnst, auf Flickr
dinus
Beitrag von dinus » Dienstag 5. Juli 2016, 13:46
Hallo Dietger,
tolle Bilder. Diese Häuser hätte ich jetzt entzerrt damit Sie nicht gleich umfallen. :-)
Gruss Dinus
Bilder
TZ31 & GX8
