Neue Firmware Version für S5II & S5IIX
Slayer
Beitrag von Slayer » Montag 16. Oktober 2023, 15:23
Wiesbaden, Germany, 16th October 2023 -
Panasonic has announced that the company will release a new firmware update program for its LUMIX S5II and S5IIX cameras to enhance performance and usability. The firmware program will be available to download free of charge from the LUMIX Global Customer Support website https://panasonic.jp/support/global/cs/dsc/ on 24 October 2023.
Panasonic continues its philosophy of continuous improvement through the implementation of future-ready firmware solutions for its mirrorless cameras to deliver innovation and value for its customers.
S5II Firmware Version 2.2 / S5IIX Firmware Version 1.3
· AF-Point Scope function
AF-Point Scope function to magnify the focus position during AF has been added.
· High Resolution Mode
The shutter speed at high resolution mode can now be set to max. 8-second with the long exposure noise reduction applied. Thanks to the image stabilizer, [Handheld High-Res] mode has been added to enable recording pictures with higher resolution even without using a tripod.
· Improved MF Assist
It is now possible to magnify the full screen mode display in MF Assist up to approx. 20x allowing more precise MF.
•Other trademarks and trade names are those of their respective owners.
•All functions may not be available depending on the situation.
•Design and specifications are subject to change without notice.
Slayer
Re: Firmware Version 2.2 for S5II & Version 1.3 for S5IIX
Beitrag von Slayer » Montag 16. Oktober 2023, 15:24
Jetzt hat auch die S5II wieder die 8 Sekunden im HiRes Modus. Das gefällt mir ;)
Thorsten_K
Beitrag von Thorsten_K » Montag 16. Oktober 2023, 16:22
und hier die deutsche Presse Mitteilung.
https://www.panasonic.com/de/corporate/ ... s5iix.html
Thorsten
So einiges an Equipment...
FlyandHunt
Beitrag von FlyandHunt » Montag 16. Oktober 2023, 20:06
High Res aus der Hand und der MF Zoom gefällt mir! Sehr gut!
S5 II / S5 - LUMIX 20-60mm F3.5-5.6 / LUMIX 24-105mm F4 / LUMIX 85mm F1.8 / SIGMA 35mm F2 / SIGMA 70-200 F2.8 / SIGMA 150-600mm F5-6,3 | Pentax SMC 50mm F1.4 / Pentax ASAHI 135mm F2.5
karatom
Beitrag von karatom » Dienstag 17. Oktober 2023, 09:20
hm, wieder kein Pre-Burst ????
also, weiter keine Kaufoption.
Vielleicht warte ich auf die S1Rii.
Gruss aus Schweden
Lumix G9ii
Panasonic 12-35mm f/2.8, 35-100mm f/2.8, 100-300mm v2, 25mm f/1.7
Olympus 60mm f/2.8 Makro
https://www.instagram.com/alter.schwede69/
https://www.flickr.com/photos/thomaskehl69/
https://youpic.com/photographer/alterschwede69/
sardinien
Beitrag von sardinien » Mittwoch 18. Oktober 2023, 08:35
Den Video Pre-Burst der S5I oder G9 habe ich noch nie verwendet. Da finde ich eine normale Videoaufzeichnung (s/s....) entspannter und sicherer. Anders sieht es mit dem SH20 Pre (1,5 Sek.) RAW Foto Modus der G9II aus. Den würde ich gerne an der S5II sehen, um in gewissen Situationen die SH30 RAW Flut einzuschränken. Sollte dies nur via einer SSD Aufzeichnung zu realisieren sein, wäre mir das egal.
Servus Gerd
G9II + f/1.8 8 mm fish bis f/4-6.3 100-400 mm
S5I/II/S1II + Lumix:f/1.8 35 mm+50 mm+85 mm f/2.8 100 mm Macro f/4 24-105 mm f/4.5-5.6 70-300 mm Sigma:f/1.4 20 mm + f/2.8 14-24 mm + f/2.8 105/210 mm Macro + f/5.6 500 mm
karatom
Beitrag von karatom » Mittwoch 18. Oktober 2023, 08:40
den Pre-Capture Raw Modus nutze ich sehr viel und verstehe nicht, wieso man eine Funktion,
die so gut funktioniert beim nächsten Modell weglässt, und sich stattdessen so stark auf Video fokussiert...
Es gibt ja jetzt die Winter-Cashback Aktion, vielleicht werde ich schwach.
Oder weiter warten, die S5 ist ja immer noch sehr gut !
Gruss
Thomas
Lumix G9ii
sardinien
Beitrag von sardinien » Mittwoch 18. Oktober 2023, 08:56
In welcher PANA l-Mount Cam gibt es einen Pre-Capture RAW Foto Modus?
Servus Gerd
karatom
Beitrag von karatom » Mittwoch 18. Oktober 2023, 09:11
sorry, war die OM-1, aber den Pre-Burst Capture oder wie auch immer,
den nutze ich oft
Lumix G9ii
Beitrag von mikesch0815 » Dienstag 24. Oktober 2023, 08:11
https://av.jpn.support.panasonic.com/su ... m2_dl.html
Die Firmware ist erschienen...
FlyandHunt
Beitrag von FlyandHunt » Donnerstag 26. Oktober 2023, 09:27
Interessant:
Das konnte anscheinend meine S5 auch schon, aber nie genutzt oder gesehen.
Ich weiß auch nicht welche Einstellungen ich falsch habe an meiner S5, es funktioniert nicht, passiert einfach nichts.
An meiner S5II geht es ohne Probleme.
Thorsten_K
Beitrag von Thorsten_K » Mittwoch 10. April 2024, 16:14
es kommt eine neue Firmware für die S5ii und S5IIx heraus. Am 22. April.
LUMIX S5II Firmware 3.0 und LUMIX S5IIX Firmware 2.0
Details im Link:
Thorsten
Beitrag von Jock-l » Mittwoch 10. April 2024, 21:38
Danke für den Link- ich bin neugierig reingestolpert und habe -im fotografischen Selbstverständnis- erstmal den Kopf über "Content Creator" geschüttelt, aber es trifft den Nagel auf den Kopf (Podcasts, eigene Filme, ...).
Das Update zielt in Richtung Echtzeit-Feedback, Infotransfer an Mitwirkende (zusätzliche Monitore), Kompatibilität mit Adobe Camera to Cloud ... wird für eine große Masse der Hobbyisten informativ und ungenutzt erscheinen, zeigt aber daß sich Pana dem Wettbewerb mit anderen Marken stellt.
Interessant wäre für Filmer, ob diese Möglichkeiten ausschließlich für KB oder auch für Geräte aus der MFT-Linie -sofern noch nicht bereitgestellt- verfügbar wird.
Slayer
Beitrag von Slayer » Donnerstag 11. April 2024, 08:20
Thorsten_K hat geschrieben:
Da sind tolle, neue Features dabei.
Prinzipiell ist das mit der Proxy-Video-Datei eine prima Sache. Aber, wie Jürgen schon angemerkt hatte, eher für eine Spezielle Zielgruppe.
Die neuen Autofokusfunktionen (wie bei der G9II), sowie der Pre-Burst Modus sind da vermutlich schon eher für mehrere Nutzer interessant.
So langsam überlege ich auch zu wechseln :P
P.S.: Auf Grund der neueren Versionsnummern und Thorstens Hinweis, habe ich den Titel mal etwas allgemeiner gehalten und die Versionsnummer entfernt.
Thorsten_K
Beitrag von Thorsten_K » Donnerstag 11. April 2024, 08:41
Slayer hat geschrieben:
Also ich finde die Proxy Geschichte spannend, vor allem wenn es geht SSD Aufzeichnen und auf SD Proxy zu schreiben ( hab leider dazu noch keine Infos ob dies geht).
Dann hätte man zumindest auch eine Backup Lösung ;) Besser kleine Bitrate als gar nix :D
Aber ja, ist ein Feature was nicht jeder braucht.
Thorsten
