Firmwareupdate G9II
- j73
Firmwareupdate G9II
Guten Morgen,
es gibt ne neue FW für die G9II:
1) RAW video output over HDMI to Blackmagic Design external recorder
- [5.7K] / [C4K] / [5.8K (4:3)] / [4.4K (4:3)] 12-bit RAW video data can be output over HDMI to Blackmagic Video Assist 5" 12G HDR and Blackmagic Video Assist 7" 12G HDR, to be recorded as Blackmagic RAW.
* DaVinci Resolve or DaVinci Resolve Studio is required to play back and DaVinci Resolve Studio to edit Blackmagic RAW data.
* Please refer to the Blackmagic Design website for the information on the corresponding firmware version of Blackmagic Video Assist 5" 12G HDR and Blackmagic Video Assist 7" 12G HDR.
* All functions may not be available depending on the situation.
* When recording in C4K 120p/100p or 5.7K 60p/50p, constant bitrate 5:1 or less is recommended for SSD recording and 8:1 or less for SD card recording.
2) RAW video output over HDMI to ATOMOS external recorder
- [5.7K] / [C4K] / [5.8K (4:3)] / [4.4K (4:3)] 12-bit RAW video data can be output over HDMI to ATOMOS "Ninja V" "Ninja V+" "Ninja" "Ninja Ultra" "Shogun" "Shogun Ultra" "Shogun Connect" devices, to be recorded as Apple ProRes RAW.
* Please check here for compatible firmware versions of external recorders.
* "Ninja V" "Ninja" "Shogun" does not support some RAW video data.
* Software that supports Apple ProRes RAW is required to edit RAW video recorded.
* A LUT (Lookup table) exclusively designed for RAW video is available on the following customer support website to make the same color grading as V-Log/V-Gamut.
https://panasonic.jp/support/globa ... _raw_lut/
Others
- Operational stability when using in some storage devices has been improved.
- There were cases where horizontal lines would appear in the image when capturing JPEG photos in SH Burst Shot mode. This bug has been fixed.
- Improved operational stability.
Others
- Hobbyfilm
Re: Firmwareupdate G9II
Hi.
Thanks for your push. Meine Videowelt wird sich freuen.
Gruß Hansi
Kamera: Lumix GH6,G9M2,S5IIx,Ninja V+.Leica 12-60,LUMIX G 12-60, S 20-60, Sigma 16 und 30mm,
Bearbeiten: Magix VPX16, Vegas Pro22, DaVinci Resolve 19 Studio, DxO PhotoLab 7.1
Website
Website
Firmware V2.2 ist jetzt online.
Der Link von j73 funktioniert.
G9, G9M2
PL 9/ f1.7, P 12-35/ f2.8, P 35-100/ f 2.8, P 25/ f1.7
P 100-400/ f4.0-6.3, Oly 45/ f1.8
S9 + P18-40/4.5-6.3, TTArtisan 40/ f2.0
Fotos
Fotos
Danke, bin gerade am Rechner, da kann ich das gleich erledigen ... ohne viel Suche
- Holger R.
Es gibt ein Firmwareupdate V2.3 wie hier schon erwähnt. Laut mehrfachen Infos in Facebookgruppen, scheint es nach dem Update Probleme mit dem AF bei Videoaufnahmen zu geben. Wer also filmt, sollte das Update vorerst nicht machen
Gruß Holger
Flickr-Best-of
-GM1, G9, OM-1, OM1 II
Flickr-Best-of
- j73
Es gibt eine FW Version 2.4 für die G9II:
- Enhanced the security of products.
Das erhoffte AF-Update ist leider nicht dabei
GH5II und GH7 bekommen übrigens die gleichen Verbesserungen.
Sollte man (,ich) das machen?
- Lumix4Video
Sicherheit und Stabilität hört sich erstmal sinnvoll an.
Sie hätten es sicher nicht veröffentlicht, wenn sie es nicht für sinnvoll halten würden.
Bei mir gab es mit GH7 und G9M2 keinerlei Probleme beim Installieren der neuen Updates (wie bisher immer).
Sven
http://photo-video-works.com/
Lumix GH6, GH7, G9M2 und GX9
Sven
- j73
Schadet in jedem Fall nicht.
ich habe mir gestern, weil mein i-mac das Update nicht durchführen wollte, beim Fotohändler das neue Firmwareupdate drauflegen lassen. Lt. Panasonic wg. der verbesserten und schnelleren Autofocus-Performance und verschiedener anderer Verbesserungen.
Was mich jetzt aber wirklich frustriert ist, dass dafür zumindest im Display der erweiterte Telebereich weg bzw. entfallen ist. Und das ist schon sehr sehr ärgerlich.
Stattdessen wurde bei Sonstige Foto (1) nach Stummschaltung der Button Drop-Zoom eingefügt. M. E. hat der aber nichts mit dem telebereich zu tun......
Hat jmd. ähnliche Erfahrungen gemacht oder hat einen Tipp, was ich machen könnte?
- j73
In der Nachbearbeitung croppen ... der erweiterte Telebereich ist nix anderes als ein nett verpackter Digitalzoom ... Braucht man nicht wirklich.
- j73
Firmware-Updates für LUMIX G9II (Version 2.5)
- Kompatibilität mit LUMIX Flow Version 1.3 oder höher
- Verbesserte Startzeit für ein schnelleres Aufnahmeerlebnis
- Bluetooth-Unterstützung für DJI RS 4 Pro / RS 4 / RS 4 Mini⁵
Moin zusammen,
kleine Berichtigung. Laut Livestream von Lumix bekommt die G9II nur die verbesserte Startzeit. Eine Anbindung an die Lumix Flow App ist leider nicht dabei, dafür aber ein Update für die Lumix Lab App.
https://youtu.be/EbMdfYnkhlc?si=AAw8w1xkqvSQFiGM
Wer sich nicht das gesamte Video anschauen will kann gerne ab Minute 5:26 einsteigen.
G9, G9M2
Fotos
Fotos
- j73
Hmmm ... Meine Info ist aus der PressemitteilungNoaH hat geschrieben: ↑Freitag 17. Oktober 2025, 08:22Moin zusammen,
